Hey Guys,
Unfortunately the previous owner installed an aftermarket headunit and has made a bit of a mess out of it.
I'm a novice, so please bare with me.
He's made a mess of the wiring and the problem is; As soon as I turn the key in accessories my parkers and taillights stays on, the fuse for the brake lights/horn blow whenever I try and insert a new fuse. The big problem is because there is a short and I can't get a fuse in there, my brake lights doesn't work.
I've checked the wiring for the head unit, and at the moment now, there's only a constant wire directly from the battery and a ground wire connected. Can I rule that out as the problem?
I've taken a few pictures of some wires that aren't connected and I was hoping that you guys can help me identify them, this is a 1980 200b.
Behind the headunit.
Under the footwell.
I don't have the money to take it to a professional auto electrician so ideally I'd like to solve the problem privately so any help will be appreciated.
Again, I am a rookie, so any other suggestion or advice will be appreciated.
