So this is how it went. I took it in and my rear left shock is rooted, which I didn't bother checking because they are only 4 months old. the guy i saw was great, he tracked down my receit, I bought shocks from another pedders shop and lost my original receit. I am going to get an up grade on the shocks i bought before and just apy the diffence, just like a lay buy
. the ones I am going to get lower the car by 19mm and hopefully are firmer. I am hoping that when i put these in it will help with the under steer i get when I am going hard in to a left hander. What I also noticed was that you can see that the left hand front tire has wear on the out side edge where it loads up when going hard in to a right hander and the tire rolls over on itself untill the the ass end lets go. The right had front tire has no wear at all on the outside edge so from what i can tell the traction gives way before the wheel loads up enough to roll over on itself. It could be the shocks, but I still get the feelng that it is a camber issue.
So what I am going to do is change the rear shocks which will lower it 19mm. then I will change the front shocks and springs and lower it 19mm there as well. I will probably go with pedders front springs and shocks unless any of you guys ahve a better idea. I think the pedders springs will be good but maybe I could get better front shocks? If this fails me I will have to get a good wheel alignment and get the camber checked, if it is all out of whack I guess I will have to get an ajustible camber kit.
Any thoughts at all guys are more than welcome.
