1600 wont crank http://www.ozdat.com.au/forum/viewtopic.php?t=29923 |
Page 2 of 3 |
Author: | Nissanman [ Tue Oct 23, 2012 10:53 am ] |
Post subject: | Re: 1600 wont crank |
No, we should be able to get this going. You will need a Multi Meter and some patience though |
Author: | datdrift [ Tue Oct 23, 2012 11:35 am ] | |
Post subject: | Re: 1600 wont crank | |
does it crank when u put a screw driver across the solinoid? got dash lights ,charge/oil ?
dont worry about it being a auto loom. these work fine in a manual car providing u have joined the 2 wires running down transmission tunnel as nissanman said. were you getting power from either (black,yellow tracer) before joining them ?
Author: | jono83 [ Tue Oct 23, 2012 12:55 pm ] |
No power at them at all |
Author: | jono83 [ Tue Oct 23, 2012 1:00 pm ] |
Ok I have joined the two wires that go down the trans tunnel and still have nothing no power up the top there is a relay if thats not hooked up correct will that do it |
Author: | Nissanman [ Tue Oct 23, 2012 1:45 pm ] |
Have you checked the fuses? The Ignition switch must switch power to the START terminal. As I said you need to look for some voltages. If you don't have a multi meter use a simple 12V test lamp to probe in the rear of plugs and such to locate voltage. |
Author: | datdrift [ Tue Oct 23, 2012 1:58 pm ] |
could be starter relay not connected right. in the service manual its got battery lead to starter,behind lead (same terminal )is a white wire ,this connects to alternator and fuse box and has a green/wite tracer wire heading off to ignition (between alt n fusebox). the black/yellow tracer wire from spade terminal on starter goes to starter relay.then another black/yellow comes off and to ignition .this wire has another 1 joined going to the auto switch . there is a 3rd wire connected to the starter relay this 1 goes straight to auto switch . so in theory you can bypass starter relay.. I would post the diagram up but no camera. hope this helps |
Author: | jono83 [ Tue Oct 23, 2012 5:13 pm ] |
Yea sort of |
Author: | jono83 [ Tue Oct 23, 2012 5:53 pm ] |
Not having any luck who wants it I have power everywere except the black and yellow wire im so Over it now been trying all week to get this sorted should have left my other loom in atleast it turned over What am I doing wrong I think I am beter of paying someone to do it |
Author: | bobs your uncle [ Tue Oct 23, 2012 6:08 pm ] | |
Ok this thing is realy starting to anoy me to the point im reasy to burn it lol
FREE.to a deserving home 1 gallon of petrol and a box of matches,any takers?
The original loom was hacked up and bits added on every were So I thought I would get a new loom got one that was standard not cut choped or anything put It in and it wont crank any ideas im stumped Starter is fine Changed both engine and dash loom |
Author: | jono83 [ Tue Oct 23, 2012 6:15 pm ] |
Crossed my mind more times than one |
Author: | datdrift [ Tue Oct 23, 2012 7:02 pm ] |
may have to unwrap your loom and trace it all back.does it crank when u put a screwdriver across where the ignition wire goes on starter to the power lead on starter? |
Author: | jono83 [ Tue Oct 23, 2012 7:31 pm ] |
Yea it does its annoying that its not playing th game |
Author: | datdrift [ Tue Oct 23, 2012 7:58 pm ] |
the white wire connecting to starter is your fusible link wire.it could be fried inside.its might be the problem .see if you get 12v all the way to fuse box |
Author: | jono83 [ Tue Oct 23, 2012 8:56 pm ] |
Ok this is what I found power every were so took plug of the ignition barrel We bridged wire power to ignition wire then power to the starter wire and bang cranked over straight away so that means my problem is in my barrel Next puestion has anyone got one? |
Author: | datdrift [ Wed Oct 24, 2012 2:11 pm ] |
Sweet.i will have a ignition,but finding 1 with a key may be difficult .I will have a look next time im out at my datto farm |
Page 2 of 3 | All times are UTC+11:00 |
