KYB Z31 is good value @ around $250 a pair.
They are better rate than the R31 KYB & a better fit than the R31 as they are around 15mm shorter.
This allows a 200 mm free length spring to fit perfectly.
Also you need to take into consideration the number of coils & diameter of the wire to select the correct
bump stop length. You will need the correct gland nut to suit the R31 tube.
