Ka24 tps sensor wiring http://www.ozdat.com.au/forum/viewtopic.php?t=30667 |
Author: | trb012 [ Tue Feb 12, 2013 8:12 pm ] |
Post subject: | Ka24 tps sensor wiring |
Hi guys im using a ka24 throttle body off a pintara and am trying to track down a wiring diagram to be able to wire up the tps. The tps has 3 wires on it a red white and black im asuming black is earth but the others not sure can anyone help? |
Author: | Nissanman [ Tue Feb 12, 2013 9:14 pm ] |
Post subject: | Re: Ka24 tps sensor wiring |
Typically, the TPS is a simple changeover contact. i.e 2 wires are continuous at idle, the bottom and middle for example. Then, at full throttle, the top wire is connected to the middle wire. Or vice versa. Attachment:
Just use a test lamp or ohm meter to verify
Author: | trb012 [ Wed Feb 13, 2013 8:50 am ] |
Thanks mate |
