So is a subi r160 LSD stronger then a datto open r160?
I run a std viscous r160 lsd in my legacy,aprox 300 flywheel hp and not a problem,highly doubt a 40 year old datsun r160 would take the same punishment....
That's what I was thinking, I just see no point swapping diff's when the new one is no stronger.
From what I can tell with my diff (it's still in the car) it has up and down play and in and out play on the left hand flange so I think it is probley a bush or thrust washer and probley the spider gears too, it goes clunk when I spin it over by hand.
II was tryning to say a r160 from a datto is weaker then the r160 lsd in the suby...
I have another question about the diffs, I have read that the viscous diffs behave like an open diff after 50000 kms, can the LSD action be restored by replacing the diff oil with a quality oil or will it need rebuilding? Thanks
my lsd has 140,000 kays and still works fine
