180B breaker points dizzy to bosch electric dizzy http://www.ozdat.com.au/forum/viewtopic.php?t=30963 |
Author: | oliverbones [ Tue Apr 09, 2013 12:41 pm ] |
Post subject: | 180B breaker points dizzy to bosch electric dizzy |
hey guys. ive read on here about having to add a "modulator" when replacing the original breaker points distributor with a bosch bluebird 2 electric distributor. whats the modulator for? do I need it to get some fire in my pistons? also, I read I needed a new coil, so I got a bosch gt40t coil. I wired the + and - according to my old coil. I cut the long white resistor from the circuit. but I don't know which wires go where coming out of the distributors. my old dizzy has a blue wire and a green wire going into my wiring loom. blue attaches to the left of old dizzy, green attaches to the right. my new bosch distributor has a pink and green wire coming out of it... im wanting to attach green (dizzy) to green (loom), and pink (dizzy) to blue (loom)... but im not sure, so best I ask here where you all know what youre doing!! cheers oliver |
Author: | datdrift [ Tue Apr 09, 2013 1:37 pm ] |
Post subject: | Re: 180B breaker points dizzy to bosch electric dizzy |
pink goes to +side of coil green goes to - side of coil |
Author: | oliverbones [ Wed Apr 10, 2013 1:26 am ] | |
Post subject: | Re: 180B breaker points dizzy to bosch electric dizzy | |
cheers datdrift...green goes to - side of coil do you know anything about the module or modulator that keeps getting mentioned? im hoping its for EFI or something so I wont need it... thanks again ![]() |
Author: | old-tin [ Wed Apr 10, 2013 4:08 am ] |
the module is bolted to the dizzy under the cover that hangs off the side. don't most gt40 coils have to be used with a resistor? |
Author: | datdrift [ Wed Apr 10, 2013 1:45 pm ] | |
gt40 R coils are the resistor type used for points
Author: | datdrift [ Wed Apr 10, 2013 1:50 pm ] | ||
Post subject: | Re: 180B breaker points dizzy to bosch electric dizzy | ||
Author: | oliverbones [ Sun Apr 14, 2013 12:18 pm ] |
hey guys. cheers for all the info... so I took that coil back, now ive got a good one ive installed the new dizzy attached pink to + green to - (there was another cable coming from here, does this need to be connected anywhere else?) plugged the cable from coil to dizzy cap attached the wires from each end of the long white resistor to the same side which cancels that resistance true? theres no other resistors in this line now. turn the key and im not firing up. have I missed something? ill get a new rotor and cap asap. also firing order is 1-3-4-2 number one piston is the one toward the back of the engine isn't it? thanks in advance guys... all your other info was great thanks |
Author: | old-tin [ Sun Apr 14, 2013 12:26 pm ] |
no 1 cylinder is at the front |
Author: | oliverbones [ Sun Apr 14, 2013 12:58 pm ] | |
ok well that's never gunna start with the way id wired the plugs...so ive now run piston 1 (front piston) into the dizzy spot where the rotor sits when I have the fan belt timing point set to the correct timing spot. then Ive run 3-4-2 in counter clockwise on the dizzy cap still no spark... heres a stupid question... where does the dizzy and coil suck power from, as ive only got these plugged into each other... I have a feeling I need to plug the cable going into the white ceramic resistor (which is now totally disconnected to coil) back up to the coil... is this right??? |
Author: | oliverbones [ Sun Apr 14, 2013 1:07 pm ] |
that cable going from the loom into the ceramic white resistor is the + coming from battery isn't it? that needs to go onto my + on the coil but bypassing the resistor im assuming... ???? |
Author: | datdrift [ Sun Apr 14, 2013 3:17 pm ] | |
yes you need the power to go to + side of coil. join both wires together that went to resistor and there should be another that went to + side of coil,turn ignition on and using a test lamp see which one has power connect this to + side of coil
Author: | travm182 [ Sun Apr 14, 2013 4:35 pm ] |
Theres a black and white wire that is originally on the ballast resistor, this needs to now go on the positive side of your new coil (HEC715 is recommended). Make sure you cover the wire that originally was screwed near the condenser on the side of the original distributor. The first spark lead should usually be the one at the closest to you and on the left. |
Author: | oliverbones [ Mon Apr 15, 2013 10:30 pm ] |
hey guys. thanks so much. this worked a treat. running so much smoother with the new dizzy. I set the dizzy up by eye and it kicked over and sure enough, timing is bang on. much better than the breaker points... ill be back soon with more ridiculous questions im sure! installing a twin su carby in the next week or so... wish me luck!!! |
Author: | travm182 [ Tue Apr 16, 2013 3:25 am ] |
We are always happy to help mate! I actually installed mine a couple of days ago too. |
