Firstly, I apologise for the Subject. But the truth is, I dont actually know what it is called.
I would like to know, what the hose coming up from behind the exhausts under the carbie, and connects into the intake manifold below the carbie.
This is also where the Valve Saver was being fed in.
Not long after purchasing the car (early 2013), we quickly found that something was not right. Turns out, the plate that had all these lines connected, was a bodge job put together with a thing bit of sheet, some plastic nipples and a hot glue gun.
So starting the car one morning quickly turned into a big mess.
In my panic, driven by the fact that I had no idea what this part exactly was, I proceeded to the workshop...
Couldn't find a nipple to suit, so I made one.
And the result.
So to the point, my main questions are;
-What is this black hose?
-Does it need to be plumbed into where it is now?
-Is this the correct place to feed Valve Saver?
-What on Earth is supposed to be there anyway???
