Trying to track down a finned rear cover for an R200 long nose.
I know of the following kinds which suit potentially both short nose and long nose:
1. Greddy S13 etc. cover (multifit)
Cast Aluminum
+900cc, baffles, port
$355 USD
1.5. Greddy and R32 etc. cover (multifit)
Cast Aluminum
$355 USD
2. GKTech S14 cover (multifit)
Billet Aluminium and funky colours.
$479 AUD and currently out of stock
3. Nissan OEM Z31 Turbo VLSD cover
+900cc, baffles and port
4. Nissan OEM S13 Diff Cover
38351-40F05
+?cc,
Does anyone have a different version that will fit a long nose R200?
I'm thinking the cheapest version at the moment is the OEM Nissan version from an S13/S14 etc. which has the fins and small capacity increase (?).
Ideally I'd like to get my hands on a Z31 because they increase oil capacity have the standard bolt holes for both attachment to the diff and the moustache bar (85mm instead of 120mm), but I don't see many of them for sale at the moment.
The S13etc. covers look like they have multiple bolt holes on the back for a different way of retaining (not using a moustache bar like the Datsun 1600 for example), and I'm not sure the Datsport/MadDat moustache bar will fit the 120mm bolt spacing and bolt dia.
Most of the later model covers also look like they have larger bolts to hold the cover on the back. The Z31 looks like it's the correct dia for the bolts.
I'm interested in keeping the diff oil cool for when I do a few track days. In the past the R180 would froth the oil (using Motul Gear Competition 75W140) out the breather, so I put a baffle in the back of the cover and also added an extension to the breather to minimise oil coming out the back of the diff. I can only assume it was getting reasonably warm doing upwards of 220km/h and the oil didn't like it. From memory when I was running the Castrol SAF-XA it didn't froth as much. The other option is to run a diff cooler with pump, but considering I mostly only do sprints (stay out the track at most 20 minutes), then it's probably not needed.
