It is currently Mon Apr 29, 2024 4:12 pm
PostPosted: Mon Feb 17, 2014 9:55 pm
Just wondering what radiators people are using after they've done engine swaps and do you have any issues?
Im putting a 1jzgte into a 200b and will probably have to get something custom made to suit the room or lack of after the motor goes in.
Do many people rear mount the radiator in the boot?
Thinking it would probably heat up the fuel cell.
thanks
PostPosted: Mon Feb 17, 2014 10:11 pm
What is a 200b :?:
PostPosted: Tue Feb 18, 2014 9:38 pm
figure that out once the egine is mounted
PostPosted: Tue Feb 18, 2014 10:01 pm
^ +1
and don't use a cheap chinese unit. you dont want to sacrifice cooling with that kind of conversion
PostPosted: Wed Feb 19, 2014 10:48 am
What are you going to use the car for? Drag? Circuit? Show? etc.
My recommendation is to find something that has a similar inlet/outlet as the 1JZ, make sure the core size is similar (that is surface area and water capacity) and then find out whether this size radiator will fit in your engine bay. You can get a catalogue of OEM style radiators from your local radiator shop and start measuring 'em up.
I have a feeling the 1JZ is a fairly long motor, so getting the radiator to fit on the front of the car may be difficult. Fit the engine first as these guys have said. You may have to modify the trans tunnel/fire wall and slide the engine back to get everything to fit?
Mounting radiators in the boot is a pain, and you miss out on all that lovely airflow at the front (if you are tracking the car...)
PostPosted: Wed Feb 19, 2014 6:22 pm
Surely a falcon or commodore one may fit. Or a hilux one even from some year model
