Know's:
-SC14's off a Toyota 1G-GZE work well on L4 engines and are reasonably easy to adapt, using the A/C mountings.
-SC14's have a 125mm pully on them, and with a 175mm crank pulley, that'll get the SC spinning to 9800RPM at 7,000 engine RPM. That's below the 10k rule of thumb limit.
-Plugging the numbers in, an SC14 will be pumping 30.6lbs/min of air @ 9800RPM (assuming a 90% pump efficiency, note: that is not compressor efficiency which will be down around 50%.) Thus at the manifold you'd expect around 14-15PSi of boost, which while on the high side for a blower, with good intercooling, fuel mapping and E85 shouldn't be a problem.
-An L18 with an open 45cc head, 87mm Flat-top pistons, 1mm HG and 0mm deck height has a compression ratio of 10:1
-An L4 EFI inlet manifold is hard to find (but I've got one.)
-An intercooler from a 7MGTE or XR6 turbo both have inlets and outlets on the same side, and would probably fit in the nose of a 180b, and be a good (+cheap) choice. XR6 intercoolers are on sale now for $30
-E85 (or E-Flex from pump fuel from Caltex or United) has awesome anti-knock characteristics.
-The Works 72 cam I've just bought should work well given a limit of 7100RPM.
-Supercharges are good in that it's very hard to get tempted and just wind up the boost that little bit more. Thus the temptation to fiddle with it once set up is removed
-supercharged vehicles with BOV's at full noise sound amazing (throttle plate between SC and inlet manifold, not pre CS as in many factory applications.
Assumptions
Plugging the numbers in gives: 206kW at the crank, or somewhere around 160/170 very instant / very torque'e RWkW. Which going from word on the street in the 4AGZE circles is about the best you can expect form an SC14. And I think that'd be a whole lot of laughs in a 180b and more then enough on 205/50R15's. Be good at the tack/hill sprint/club car etc... and as mentioned never tempted to wind it up just that little bit, because that would push parts past the safe zone of operation and the effort to do so on an SC setup.
Unknown's
-Best way to get direct fire ignition / sequential injection on an L4, I'm thinking an EDIS 36/1 crank pulley with a home signal from a modified distributer, but I'm coming up short? Obviously running wasted spark/batch fire with a crank only trigger would be a far easier/simpler option.
-Whether this actually would work and is a good idea. Compression too high / too much boost?
-Will a standard fibre head gasket be up to the job (assuming good tune, faced head, faced block, ARP studs.) Or will a MLS one be required.
-Injector requirement, 550cc or larger?
-Exhaust size, 2.5" be a good size?
-Has anyone thought to do this before.
-Costs: I'm thinking ~$7,000 including an engine rebuild and an ECU.
This is speculative at the moment but I had to post it up to get peoples feelings and see whether or not this would be a viable route to go. Other options would no doubt be cheaper CA/SR/3SGE Beams/FC20... but the 180b I've bought has the original motor and well it'd be nice to keep it in there if I ever get serious about modifying it beyond the Twin solex's/cam, extractors and exhaust I've already got. Turbo would be cool but I'd not want over 200RWkW for a streeter that I and the girl will be doing club events in. It just seems like a more interesting alternative.
Look forward to reading your opinions
Regards
Jordan
P.S: attached is a
spreadsheet I've been working on for far too long. you may or may not find it of use/interest. but it's been helpful to me in working through Ideas on my TA22 race car.
