The number of external terminals gives it away.
From what I can see in the pic. there are the S, L spade terminals and the A and E post.
That implies it is internally regulated.
The terms "Internal" or "External" refer to whether the alternator has it's own Voltage Regulator, located somewhere in/on the alternator, or whether an additional VR is necessary to control the charging circuit.
By definition, an Externally Regulated Alternator will have more wires between the two devices.
Relevant connections for that example.
High output alternators are only required for high loads.
If the car doesn't have a sound system that destroys bowels at 50 paces, 50A will be more than adequate
Even the Bosch 35A is more than adequate.
My favourite soapbox rant is about "fitting a nuclear rated alternator" to a standard car.
For a start, the need is largely not there.
Then you must consider the engine wiring loom current rating.
Nissan would have dimensioned the wiring to safely handle the alternator maximum output e.g. 35A.
Connecting in an alternator that is CAPABLE of producing 50 or 60 amps, well, you can see where this is going
So, do your sums and be honest with yourself.
If a higher output is electrically necessary, for whatever reason, then the associated wiring will need to be, protected, upgraded, and/or supplemented with another power distribution system.
None of these requirements are difficult to achieve but unless you enjoy engine bay fires, they are absolutely necessary
