....Thanks Nik,
That's the sort of information I was after. Can see the engineer coming out with the in depth analysis you have provided.
Will be keen to see how you go with the ducting added?
What sort of header tank are you running?
Engineer being involved may not be a good idea...
It's a combination of Engineer and trial and error.
I am running a Volvo header tank (same as TurboVan and HailesT).
I'm very keen on getting her back out on the track and see what kind of results I get with the temperature. Based on the initial street tests, it looks pretty good.
The other thing I did was seal the bonnet off against the "bonnet latch/grille holding sheet metal" where the radiator sits up against. This stops air from going over the top through the gap between the bonnet and the radiator/latch/grille holding sheet metal of the car. This gap is quite big and would decrease the pressure drop over the radiator. Another party trick copied off more modern cars... It also stops hot air from rising and coming out over the top of the grille which then gets sucked back in by the thermo fan. Less hot air recirculation...
