OZDAT
1600 Rally Rear x member
http://www.ozdat.com.au/forum/viewtopic.php?t=33601
Page 1 of 1
Author:  Mr Dazda 13B [ Mon Mar 09, 2015 9:52 pm ]
Post subject:  1600 Rally Rear x member
The is a modern copy of my Group G Dazda X Member, A little bit of Baz at Datsport for the adjustable kit, great bit of gear, some fine tig welding by spud.
The last one reinforced and manufactured in 1985 did fine service untill some adjustability was required.
I copies some of the reinforcing from the 1980s and added a little laminating.
Author:  sutho510 [ Tue Mar 10, 2015 6:43 pm ]
Post subject:  Re: 1600 Rally Rear x member
Nice work mate is that another plate welded on top of the crossmember
Author:  Mr Dazda 13B [ Wed Mar 11, 2015 12:51 am ]
yes it is 1.5mm plate and the bottom has 3mm plate on it.
Author:  sutho510 [ Wed Mar 11, 2015 5:59 pm ]
Thats a great idea i run a r200 in my car and it use to get dragged alot and i had a 10cm stress crack form down one side of the crossmember
Author:  Mr Dazda 13B [ Mon May 04, 2015 11:41 pm ]
For thoes with adjustable rear ends on the dirt
What rear wheel alignment do you run with ?
Baz?
John
Author:  Baz [ Tue May 05, 2015 10:34 am ]
Zero camber, 4mm of toe in.
Toe in will influence turn in. Be prepared to adjust to suit your style of driving.
You will have to adapt to the different handling.
Be more aggressive into tight corners, brake late, get the tail out & make use of the extra traction.
Gear box is for going faster.
Throttle & brakes are for steering.
The steering wheel is for something to hang on to.
A tad more rear bake bias will help.
Author:  SR20Datsun [ Tue May 05, 2015 12:02 pm ]
Got any pics?
:P Cracks me up.
Author:  sutho510 [ Tue May 05, 2015 1:40 pm ]
SR20Datsun wrote:
Got any pics?
Nah sorry i did'nt take any but the crack ran along the original weld from the front of the diff to underneath the diff
Author:  Mr Dazda 13B [ Wed May 06, 2015 12:12 am ]
Thanks Baz,
Happy to chuck it into corners more :)
Great Kit Baz
Author:  Baz [ Wed May 06, 2015 1:02 am ]
Fill the rear xmember & trailing arms with 2 pack expanding foam.
Author:  Mr Dazda 13B [ Wed May 13, 2015 12:30 am ]
done
check , :)
https://www.phpbb.com/
