worn/damaged thrust bearing http://www.ozdat.com.au/forum/viewtopic.php?t=33673 |
Author: | 19706TN100 [ Wed Apr 15, 2015 10:17 pm ] |
Post subject: | worn/damaged thrust bearing |
i have a 1970 1600 L20B with clutch engaged and a blip of the accelerator at 1500 RPM a horrible grinding noise erupts from the bell housing, then when the clutch is disengaged the grinding noise stops. this noise has effect while in gear and in neutral. has anyone else experienced this? |
Author: | green200b [ Wed Apr 15, 2015 11:46 pm ] |
Post subject: | Re: worn/damaged thrust bearing |
Have you had the car running and driving and this has started happening, or have you up everything together and it's done it? The reason I ask is that I had a problem that sounds very similar to yours when I did a manual conversion on my Hilux, the problem ended up being that the flywheel bolts were too long. I couldn't hear them rubbing against the engine but when I put my foot on the clutch I could. |
Author: | sled510 [ Thu Apr 16, 2015 1:16 am ] |
Clutch engaged = foot off pedal Clutch disengaged = foot ON the pedal In neutral , clutch engaged. Could potentially be bearing input shaft bearing In neutral , clutch disengaged. Could potentially be throw out bearing Either way gearbox comes out and problem will be pretty obvious if noise is that bad. Check clutch disk thickness and ensure rivots aren't grinding on flywheel aswell. |
Author: | 19706TN100 [ Thu Apr 16, 2015 9:16 am ] | |
Post subject: | Re: worn/damaged thrust bearing | |
Clutch disengaged = foot ON the pedal In neutral , clutch engaged. Could potentially be bearing input shaft bearing In neutral , clutch disengaged. Could potentially be throw out bearing Either way gearbox comes out and problem will be pretty obvious if noise is that bad. Check clutch disk thickness and ensure rivots aren't grinding on flywheel aswell. thankyou for your help, I have a new clutch kit ready but I will have a good look at the mechanical clearance in relation to the clutch and flywheel. to see if any rivets or bolts are binding up on a metal surface. as well as inspect throw out brng. thanks |
