Clutch engaged = foot off pedal
Clutch disengaged = foot ON the pedal
In neutral , clutch engaged. Could potentially be bearing input shaft bearing
In neutral , clutch disengaged. Could potentially be throw out bearing
Either way gearbox comes out and problem will be pretty obvious if noise is that bad. Check clutch disk thickness and ensure rivots aren't grinding on flywheel aswell.
thankyou for your help, I have a new clutch kit ready but I will have a good look at the mechanical clearance in relation to the clutch and flywheel. to see if any rivets or bolts are binding up on a metal surface. as well as inspect throw out brng. thanks
