Firstly, I'm hopeless with elecktrickery.
Now we have that out of the way, I'm looking to fit an R31 alternator to my 1600. I've googled, and found many good "how-to's". Problem is, most of these refer to bridging a couple of wires near the regulator. I don't seem to have a regulator ?? Whereabouts would these be mounted normally ?
My 1600 has seen duty as a rally car in the past, it is possible the wiring has already been modified or the regulator removed. I do have a few extra wires running from the alternator to the +ve terminal on the starter that definitely aren't factory original.
Anyway, what can I check ? The pic below shows what I have.
Two black wires (one thick-ish and one thinner). These seem to go to earth - if I connect a multimeter from +ve terminal on battery to these two wires, I get 13-ish volts flowing.
One thick white wire with red trace. This seems to run into the wiring harness and end up on the +ve terminal on starter motor.
Yellow wire. No idea where it goes.
White / black trace wire. No idea on this one either.
Connecting either of the last two to a 12V supply doesn't get the charge light in the dash to turn on.
The two green wires in the pic are the ones that run from alternator to + starter terminal (non-original)
The new alternator has two terminals marked "L" and "S", which I believe should connect to a 12V supply and to the charge light.
So, any tips before I load it onto the trailer and hit up an auto electrician ?
