OZDAT
Help with i.d, what is my setup?
http://www.ozdat.com.au/forum/viewtopic.php?t=34327
Page 1 of 1
Author:  JaceV [ Sun Sep 04, 2016 10:53 am ]
Post subject:  Help with i.d, what is my setup?
Hi guys,
I'm after some help in trying to figure out what suspension, diff ect I have.
I need to know so I can sort out some disc brakes for the rear and the fact I need to know for my engineer.
Rear spring is 240mm overall. Red in colour.
Numbers on the strut/shock 15 3040
D 21SE05
Length is 510mm.
Also if there is anything else that you can see.
Author:  Bozo510 [ Mon Sep 05, 2016 10:54 am ]
Post subject:  Re: Help with i.d, what is my setup?
Looks like an R180 diff, but you can confirm by measuring the distance in the attached photo.
Does the engineer need to know what springs and shocks you are using?
Also is that a side pipe exhaust?
Author:  JaceV [ Mon Sep 05, 2016 5:53 pm ]
Thanks for the reply.
It measures 170mm.
The engineer has told me that with my z18et motor, I will need brake and suspension upgrade. It would be good to know so I can tell him, and plus so I can install the correct disc brakes for the rear.
I have girlock discs on the front, and 4 x 114 studs.
I was thinking of just telling him it has 200b struts etc to get me through if I couldn't work out what I had.
And yes that is a side pipe lol, its on the list to be changed...
Author:  Dave [ Mon Sep 05, 2016 6:08 pm ]
The springs / shocks / diff won't matter as far as installing rear discs. There is no "correct" disc setup, just go for the usual R31 conversion (R31 skyline discs / calipers mounted on a slightly modified R31 caliper bracket and modified or custom handbrake cables).
Something like this http://datsport.com/R31rear_disc_brake_ ... ion_C.html
Author:  JaceV [ Mon Sep 05, 2016 6:18 pm ]
Good to know!
I dont know too much about that area of a car, as you can tell.
Thanks heaps.
Author:  Bozo510 [ Tue Sep 06, 2016 3:47 pm ]
Get a picture of the front and rear calipers with the wheels off. It most likely has R31 rears.
I got my old Z18 1600 engineered with drum brake rear and 200b front struts (girlock calipers).
https://www.phpbb.com/
