Gday mate, welcome.
1: Is the tunnel size a issue my car is factory manual.
No issues here
2:Does the shifter end up through the standard position using the sr box
No. The SR box is longer so the shifter gets moved further back and the tail shaft needs to get shortened.
3: what fuel setups have people used
I run a lift pump to 2L surge tank then bosch pump. All in Boot. Annoying.
4: can the 180b tail shaft be used for the sr
Yes, but it needs to be shortened.
I run a RB non turbo box with SR bellhousing. With this combo the shifter is in the standard position and the tail shaft does not need to be modified.
