It is currently Sun Apr 28, 2024 10:07 am
 Post subject: R180 output shafts
PostPosted: Fri Oct 13, 2017 7:50 pm
Hi all,
Are the output shafts and retaining bolts different between R180 and R160 diffs. The bolts that wind into the diff centre are from a 1600 and appear too short to retain the output flange. Thoughts from those who have run an R180 in a 1600?
Cheers people.
 Post subject: Re: R180 output shafts
PostPosted: Mon Jul 02, 2018 12:55 pm
.. not sure if you were still looking for an answer to this question.
The metal dust covers on R160 axle output flanges protrude more than those designed to fit the R180 diff. The metal dust cover will bottom out on the side bearing holders (the alloy parts that hold the side bearings and bolt to the steel case of the diff) all before the long through bolt can correctly engage with the threaded retainer block that is located at the inboard end of the side gear (internally splined part).
The most common way around this problem when fitting R180 diff in place of a R160 is to carefully cut through the two spot welds that attach the metal dust cover to the axle output flange (couple of shallow hacksaw cuts will do the trick), and remove the dust cover.
On my rally cars, I always modified the dust covers and reattached them with a couple of spots of weld as they were originally, ensuring protection for the rubber side seal, which was Hitachi/Nissan's original idea. The down side of doing this is increased risk that a dust cover will be damaged, come loose and do even more damage ... your call!
Simplest fix is to carefully cut the metal dust covers off and throw them away, making sure you have not left any jagged bits to damage the side seals.
Everything works perfectly well without these metal dust covers, especially if a little excess grease is applied to the seal before reinstalling the axle output flange.
Note that if the diff (either R160 or R180) was sourced from a Subaru, there will be no threaded retainer block to screw into: Subaru diffs have internal "c" clips fitted to the side gears.
Things work best when it matters the least, and ...
