Oil pressure sensor T piece install - copper washer? http://www.ozdat.com.au/forum/viewtopic.php?t=34989 |
Author: | K1600 [ Thu Aug 26, 2021 10:06 pm ] |
Post subject: | Oil pressure sensor T piece install - copper washer? |
Hi, Currently installing a mechanical oil pressure gauge on an L20b. When removing the oil pressure sensor and installing the brass T piece do I need a copper washer? |
Author: | trb012 [ Fri Aug 27, 2021 9:27 am ] |
Post subject: | Re: Oil pressure sensor T piece install - copper washer? |
Just some thread sealant will be fine as the T piece generally don't go all the way into the block. Be sure to use a steel one as well as the brass kind can crack over time and break off in the block. Ask me how I know..... |
Author: | K1600 [ Fri Aug 27, 2021 10:39 am ] |
Thank you for the advice trb, much appreciated. Didn’t realise the brass wouldn’t last. |
Author: | Mastadd240k [ Fri Aug 27, 2021 1:36 pm ] |
How do you know this?
Author: | Nissanman [ Fri Aug 27, 2021 9:48 pm ] |
Never experienced a failure with brass fittings. It may be a result of a faulty casting? |
Author: | trb012 [ Tue Aug 31, 2021 9:11 am ] | ||
Post subject: | Re: Oil pressure sensor T piece install - copper washer? | ||
Author: | Nissanman [ Tue Aug 31, 2021 11:10 am ] |
Probably due to vibration causing fatigue in the "T". In a race car that would be a killer |
Author: | trb012 [ Tue Aug 31, 2021 3:04 pm ] |
Yep 100% mate the vibration along with the weight that was on it wouldn't have helped |
