Maybe for personal interests instead of racing?
The ka24de are common in the states and Japan. However sr20 turbo engines are used to replace them in many cases for ease of using a factory turbo engine (this I found to be the case from reading the American sites). Getting them here from there is the task but I found a few front wheel drive ka24de heads from 230 to 350au.
What 1600 road car wouldnt deserve what past OSGiken workers and customers used in limited numbers.
Maybe I should ask this question....
If a twin cam de L sereis hybrid was made available for 4500au would anyone be interested?
This would be a short block with custom weber type manifolds.
It sounds like a lot but it would still be a bargain. no?
KA24E (1971 510 5-speed) (RWD)
KA24E (12valve) : 127 rear wheel HP
stock 1990 240 SX 12valve 2400, with 2"exhaust, Sebring muffler, and K & N cone air filter (on a custom air intake/air flow meter mount.computer tweaked by Wolf Racing (
randyyork@loop.com)
KA24DE (1998 240SX SE 5-speed)(RWD)(Stock)
KA24DE (DOHC)
135.6hp @ 5300rpm
150.6ft/lbs @ 4100rpm
(actual sheet)
KA24DE (1992 240SX SE 5-speed)(RWD)
KA24DE (DOHC)
Jim Wolf Technology ECU, S & S Headers, Greddy Cat Back Exhaust, Ram Air Intake, Unorthodox Racing Pulley, 104 octane.
169hp @ 5600rpm
170ft/lbs @ 4400rpm
130hpATW with well tuned 45s, pipes and regraphed bluey dizzy with the ke24e head and higher comp would not be an impossibility and neither would....
170hpATW with the same but the DE Head.
