L20b http://www.ozdat.com.au/forum/viewtopic.php?t=6227 |
Author: | datads [ Tue Sep 27, 2005 2:40 pm ] |
Post subject: | L20b |
just a quick question, should i be worried if i can hear the tappets in my L20b, it is quiet a loud tapping, what can cause them to get lose..? i heard that when they become lose then it is nearly impossiable to ever fix the problem. any help much appreciated. cheers |
Author: | MangaNOID [ Tue Sep 27, 2005 3:38 pm ] |
Post subject: | |
you can always hear the tappets in a L engine. if its very loud though and if you know what your doing get the rocker cover off and stick some feeler guages in there! cant remember the gaps of the top of my head though. unless the thread is stuffed then you would be able to tighten them up, if they are loose. |
Author: | proL18 [ Tue Sep 27, 2005 4:54 pm ] |
Post subject: | |
gap them! inlet cold 25thou exhaust cold 30 thou inlet hot 30 thou exhaust hot 35 thou |
Author: | datads [ Tue Sep 27, 2005 5:01 pm ] |
Post subject: | |
yea i dont really know what i am doing, so might just get it cheked out, just wanted to know what it might be. cheers for the help. |
Author: | Jays_5000 [ Tue Sep 27, 2005 6:04 pm ] |
Post subject: | |
It's actually a really easy job to do. http://www.picturetrail.com/gallery/vie ... uid=786489 Use this for referance just use the L20b gap sizes if there is a difference. |
Author: | Baz [ Tue Sep 27, 2005 7:13 pm ] |
Post subject: | |
whoa hold on there inlet 10 thou inch hot exhaust 12 thou inch hot. between cam & rocker. Pro mebbe you meant hundreth of millimeter. |
Author: | lukey73 [ Tue Sep 27, 2005 7:49 pm ] | |
Post subject: | ||
gap them!
Pro i use inlet cold 25thou exhaust cold 30 thou inlet hot 30 thou exhaust hot 35 thou inlet cold 10thou exhaust cold 12thou Why such the large gap for you ? Luke |
