Ok so i put the stock carby back on and it still ran like a lawn mower (only cyl 1 and 4 firing) so obviously ignition problem. I fidled around with the distributor for ages and all of a sudden it started running on all for again.
I dont know what i did but it worked...
Put the weber back on and played with the jets, i took some jets out of a 34ADM i have lying around and put a 160 air jet in primary, 140 fuel in primary, 165 in the secondary air, 135 in secondary fuel, the power valve at 50, primary idle at 50, secondary idle with 55 and i left the e-tubes because i dunno wat they are.
Some were already in the carby, i think i only put one jet from the adm in after trial and error with the jets.
I got it to ran pretty damn well. Now its not running rich at all. It does feel a little lean though, both primary and secondary throttle. and when you stamp your foot on the throttle at idle the whole engine lags, almost stalls and then picks up.
Do you think this could be the power valve being to small? What sort of jets would you guys/gals recommend i use in this carby, remember:
Rebuilt Stock L20B, 20 thou overbore.
Slightly shaved Recon W53 Head.
Running on ULP
And where could i buy jets and gaskets etc for this carby at a resonably good price in SA?
Cheers for all the help on this subject, i hope it stays running good.
Now for a completely diiferent problem.
Steering: Once i put the weber back on i went for a drive around my property and all of a sudden my steering got extremely hard, like very hard. So i thought somethings not right here. So i got out and the tyres are ok, the wheels all look normal, steering rack looks normal.
Now i did change the front pads and havn't bled the brakes yet (no i havn't been driving it on the road) but that shouldn't affect the steering.
The very weird thing is it comes and goes, all i know something is very wrong.
Once again thanks for all the help.
datto_1600
_________________ 89' R31 Skyline Ti, 5 speed - Daily
89' R31 Skyline Executive - Slider/track whore
8' Stanza SSS - Rally Project
