Yep, Lurch has a good point about air-speed, but if the lynx manifold is going to have a big negative affect on flow when compared to the Datrally - thats not a good thing either.
The issue of poor air speed is very much just a low engine speed problem... for your rally car, there should be no real drama's. Also the fact that your running twin 40s (choke size will prob be 34-36) means that there will not be a huge low air speed issue at all through the rev range - allthough you may find an issue with flow.
I guess you have to decide if the extra flow (or lack of turbulance) gained from the datrally manifold is going to make a differance on your particular engine, with those particular carbs.
In a little while i'm going to test both a Lynx style and Datrally manifold with a set of 45's on my brothers (very mild) L18powered car - not for research purposes but because i'm gunna pinch the Datrally manifold for my car, so he will have to go to running the Lynx
FWIW, i have a set of twin 40's on a datrally style manifold on one of my L20b's and i am quite impressed with how it runs, it pulls well right through the rev range, and is quite driveable, it wasnt lacking flow either! - and although i have no facts to back up the "impressedness" or an equation to prove that i was impressed, i guess its just another thing to concider
Cheers Sean
