I have a FJ20e and box in my garage. I was thinking of eventually putting it in my gazelle since its a fairly straight forward exercise so im told, since they originally come from a S12.
My question is, is it worth my while supercharging it?
Yes
I was thinking along the lines of the cheap 1GGZE superchargers, nothing special.
Cheap way to start the adventure
Is it hard to make a mounting bracket / get it aligned properly to suit this application / motor?
Yes & No depends on your skills.
The mounting/ bracket is crucial
I realise its easier to just turbo it, but I dont want to go that path, i'd rather some low down talk, without sacrificing the top end revving.
Torque with revability is the name of the game.
Any input from people in the know is appreciated.
Martin
Take time in the design of the bracket, needs to be robust .
The whole design must be based around the crank pulley
position, first job.
I may be able to supply an outer 5pk pulley ring which is shrunk on to machined area of std crank pully. or the size.
Should give you 9 lbs boost, which is sufficient for the specs.
On L series we do this on the rear of the crank pulley. this keeps all other belts in std position and reduces stress on the end of the crank.
once the pulley is fitted you can then position the blower exactly.
Belt tension must be adjusted via idler pully.
generic/hybrid/monza/ IC.
water injection, even a cheapy version.
keep it clean & lean 13.5 af with WI.
Oh, missed this,
Only looking for standard boost, would be running a microtech MT-8 on it, probably just go for the Rx7 injectors over standard
If you go IC & WI you will get best grunt, drivability
economy, so why not try the std injectors first & save some cash.
