It's all worked out nicely for me.
I ended up using LCA's that were lengthened by 30mm in conjunction with offset 180B strut tops. This gave the tyre to guard clearance I needed.
According to the wheel aligner, the end result was 3.75 deg neg camber on one side, and 4.25 on the other. Not sure why the difference (perhaps I can't measure too well
). Using a 10m spacer on the rear side of the caster rod bushes (ie the side pointing towards the rear of the car) to reduce the amount of caster added by the lengthened LCA's ended up giving 2 deg caster. I would have liked to have run more, but was getting close to having tyre clearance issues on the front of the wheel arch at this setting.
Took it down to Wakefield Park yesterday, and managed to reduce my lap times by at least 9 secs
. That was on the initial results that were posted, and I feel I reduced my times further as the day wore on. Have to wait till the complete results are published to find out.
As well as the lengthened LCA's, I've lowered the car by 80mm front and 35mm rear, fitted better brake pads and new rotors, fitted a steering brace, and had the car dyno'ed. I guess a bit more experience on the track helped too
.Not sure how much the lengthened LCA's played in the lap time reduction, but it was a completely different car to drive
No more severe understeer - the car handled much better, with just a slight tendency for the rear end to want to lead the way round corners (which it did a few times
All in all, I reckon the LCA's have been a cheap and easy modification.
Here's how it looks now
