Only issue I have had (and only with this set of British SU's) is that I have had to drop the fuel pressure to barely 1psi or the float chambers flood. Idle fluctuating is often an indication of throttle shaft wear.
Track day today was "interesting"......
First problem, drove the 1600 onto the trailer, put the keys on the neighbour's retaining wall while I strapped the car down and then drove to Sydney. With the keys still sitting on the retaining wall 2 hours away from Sydney
Quick trip to a locksmith (big plug for Arrow Locksmiths of Wetherill Park, friendly, quick and cheap service !!!!!!), $20 later and I had a nice shiny new key, cut from the code on the ignition barrel.
First session, all good.
Second session, on with the new full slicks to scrub them in. What a blast, so much grip
Third session, back onto the R888's. After a few laps, I smell petrol so pull into the pits only to find I had let the fire escape out of the engine
$20 ALDI fire extinguisher performed well, no more fire
So, what went wrong ? The bolts holding the fuel pressure regulator on backed out, allowing the fuel line to drop onto the radiator fan which cut a nice slice in it. Fuel + hot engine apparently isn't a good combination. I count myself very lucky, only damage is a melted radiator fan, few scorched wires and lots of soot and extinguisher powder through the engine bay. Didn;t even damage the paint on the bonnet (well, maybe the underside is a little scorched under all the soot).
Good news ? A new bit of fuel line and it drove off the trailer at home.
