Here's my car. It's a B310 120Y. I don't think I've seen any of the square light models on the site so I might be the first
I had it over a year now but it has only been on the road about 6 months as the rest of the time it was sitting in the garage/getting bodywork/getting painted.
Not much to say, it has in a completely stock A12. It was automatic but I sourced all the parts (clutch, flywheel, box etc) and got it converted to the 4 speed manual. I kept the automatic diff because it has a better ratio so I get a little more acceleration out of the old engine.
I have a set of 13x7 Starmags which I have to paint and then get tyres for. So for now I'm stuck with the standard wheels.
As far as suspension goes the car has serious body roll which I want to get rid of. Right now I have set of 160J front struts which will be put on at some point but I need to get new brake pads for them and the discs need cleaning up. If I can find a 160J rear end that will get installed too, if not I'll just get a good set of aftermarket shocks and stiffer springs for the back (any suggestions on good springs to use?)
I dont see any point in modifying the A12. Instead I'll do an A14 or A15 engine swap and go from there.
Here are some pics.
