It is currently Fri Nov 01, 2024 11:13 am
 Post subject: ca20 vs ca18 Gearbox
PostPosted: Wed Nov 29, 2017 7:43 pm
what are the big differences between a ca20 gear box vs a ca18 box.
I know the ca18 box is supposed to be shorter but just want to see if anyone has any experience with the two boxes
Thanks
 Post subject: Re: ca20 vs ca18 Gearbox
PostPosted: Wed Nov 29, 2017 9:53 pm
Ca20 has an external (ish) attachment of its gear lever. I don't recall if the lengths are different. The gearstick sticks up in a different location i think though.
Been a looong time since I've had the boxes next to each other sorry.
PostPosted: Fri Dec 01, 2017 8:18 am
Thanks
The ca20 box is the earlier FS5W71b with a ca bellhousing for series 3 bluebird/pintara.
The ca18 box is later desigh FS5W71c for silvia /180sx and as already mentioned has different shifter setup although both boxs are same overall length. Go with the later one,
PostPosted: Wed Dec 06, 2017 9:33 pm
The later box is sooooo much nicer. It is roughly 50mm longer from memory and the gear stick position is further back. But as bluebird68 mentioned it's a later design and closer to that of an SR20 box and similar to an RB20 box without a 3rd main bearing.
douglasamills wrote:
1600s arent the only datsun
