The use of rack and pinion steering with our kit would be very difficult.
One would need to find a very short steering rack for this application.
The lower control arms used in our kit are approximately 100 mm longer ball joint to ball joint than that used on a standard 510.
The inner pivot points of the control arms are much closer together than an original 510. Thus the need for a short rack to keep induced bump steer to a minimum.
The longer lower control arms give reduced wheel angularity moving through their normal travel.
The 810 track Rod is nearly twice the thickness of a standard 510 and it is virtually straight.
This track rod does not flex compared to the original 510 bent track Rod.
With a good steering box and steering brace fitted one would be very hard pressed to find a difference if a rack and pinion steering was fitted.
I see your point re the exhaust manifold. This is a problem on all left-hand drive 510.
K. Beam imports in California have a well priced manifold kits to overcome this problem.
Not sure if it is shown on the site, I have seen pics of the kit & it looks
very good.
http://www.kbeam.com/index.htm
