It is currently Fri Nov 01, 2024 10:49 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 »
PostPosted: Thu Nov 15, 2012 11:01 pm
Looking to to my underside in this por15 but wondering what thinners I can use?
-1969 1600 SR20
PostPosted: Fri Nov 16, 2012 7:51 am
They have their own thinners. Are you going to spray it, or brush it ? It brushes on nicely and is easy to do.
PostPosted: Fri Nov 16, 2012 8:17 am
Yeah brush it on you will get more bang for you buck and no loss/mess in overspray.
PostPosted: Fri Nov 16, 2012 8:58 am
Was thinking of spaying just so it looks better?? It's for the under carrage of the car
-1969 1600 SR20
PostPosted: Fri Nov 16, 2012 9:01 am
My local paint shop recommend this stuff, say its as good as por and a third of the price. http://www.kbs-coatings.com.au/rustseal ... structions
-1969 1600 SR20
PostPosted: Fri Nov 16, 2012 11:35 am
I have a bit of experience with this. I would use KBS rust seal rather than POR15. Only because there the same and KBS is cheaper.
You usually dont need thinners but you have to use the POR15 or KBS brand thinners.
I brush it on. I dries nice and smooth. But preparation is key.
Fun fact I tested this. Rust seal will cure under water.
Callan
fleet:
78 200B
86 ZL Fairlane ZLane
78 ZH Fairlane 500 Barn find
85 Troopy 2H Turbo
PostPosted: Fri Nov 16, 2012 11:41 am
Sorry when I say you usually don't need thinners is beacause I wouldn't bother spraying it. The brush finish is perfect.
I would be very careful using this stuff in my spray gun cause once its in its painful to get out. Once its dry it aint coming off.
again I recommend brushing it.
Callan
fleet:
78 200B
85 Troopy 2H Turbo
PostPosted: Fri Nov 16, 2012 12:04 pm
Likewise. Spraying is just going to be wasteful and messy.
Here's mine, brushed on. Only problem I've had with it was using their "Tie Coat" product over the top of Sikaflex seam sealer - the tie coat just didn't set for some reason (but only where it was applied over the Sikaflex in the seams, it went off perfectly over the top of the POR15. I did POR15 --> seam seals --> tie coat, perhaps I should have done the seam sealing, then POR15 over the top of that ?? )
PostPosted: Fri Nov 16, 2012 12:38 pm
Oh that looks really good, I'd be happy with that finish. Thanks for the input guys looks like brush on is the way. How many liters would I need to brush on the underside?
-1969 1600 SR20
PostPosted: Fri Nov 16, 2012 4:05 pm
I brushed on my POR15 aswell. Comes out great.
One key thing i found is you need to roughen up the surface quite a lot using coarse sand paper to get the paint to stick really well. They say sandblasting is best.
Follow the instructions, dont double dip the brush into the paint tin. Pour out how much you need into a container.
Refrigerate after opening tin
This is how my underbody turned out after brushing on
I did two coats. Black first and then grey
PostPosted: Fri Nov 16, 2012 4:27 pm
That looks great. How much paint did you use?
-1969 1600 SR20
PostPosted: Fri Nov 16, 2012 4:36 pm
I think i used 1 litre of black and 1 litre of grey
PostPosted: Sat Nov 17, 2012 12:19 am
it goes a fair way. Few quick rules. Never paint out of the tin. put a plastic bag or grease proof paper between the lid and tin between uses. Stir dont shake (sorry mr bond) and do the proper prep work it really makes a big difference. I'm sure this is all on tin but you dont wanna stuff this stuff up cause its a real messy clean up job.
Callan
fleet:
78 200B
85 Troopy 2H Turbo
PostPosted: Sat Nov 17, 2012 12:21 am
I can't stress how important it is when you shut the tin put something between the tin and lid. If you dont you won't get it open again.
Callan
fleet:
78 200B
85 Troopy 2H Turbo
PostPosted: Sat Nov 17, 2012 1:23 pm
Yep KBS stuff is tops!
Users browsing this forum: Google Adsense [Bot] and 0 guests
