It is currently Tue Jun 04, 2024 7:39 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page « 1 2
PostPosted: Wed Aug 01, 2007 11:26 pm
It seems you like drift... So i dont think it will be a problem :wink:
PostPosted: Thu Aug 02, 2007 12:04 am
touche!!!
my only comment to that is 6 years ago at the age of 16, i thought of that user name, and it has just stuck
PostPosted: Thu Aug 02, 2007 9:26 am
I was only stuffing around man... :lol: Just wanted to see what you would say, the bare roof is definatly drift style
The best way to do the roof would be to take the windows out, ive seen some stuck up and riveted along the windscreens but it wont come up anywhere near as good, the windows and the black pinch weld around the doors help keep it all up there and tight
Head linnings are a complete biatch of a job, but if you decide you want it you might have to pull them out again
Simon :wink:
PostPosted: Thu Aug 02, 2007 12:33 pm
meh, it's already a nice shade of painted black, so it'll do
However if i ever need to replace front and rear screen seals (they're looking old now) i will do it properly then
thanks for the info
PostPosted: Sun May 31, 2009 10:01 am
Sorry to dig up an old thread, but though it was better than starting another.
My car's being stripped for blasting but the roof lining is mint, is it worth taking it out? Is it hard to reinstall? I heard they never fit the same :/
Thanks!
PostPosted: Sun May 31, 2009 12:05 pm
I hate it when you type a post reply and it fails :evil:
Anyway, from experience, you are probably better off getting a new lining.
The couple I've fitted have been glued/stretched into place.
Once glued in the excess vinyl is trimmed off, leaving a nice neat finish around the windscreen and door apertures.
The problem with reusing an old lining is it can be a pr1ck of a job to remove the lining without damaging it, and when you go to glue it back in, there generally isnt enough vinyl to get a decent hold on to stretch/glue it back in. Further, no matter how hard you try, you will probably end up with sags in the old lining.
Another trap is with the hood bows, I've found to get the best fit, you need to put them back in the order/place (think left and right hand side) they were removed, otherwise you'll have fitting troubles as well.
IMLTHO, you're better off shelling out for a replacement lining and saving yourself some potential grief.
Jason
What would you attempt to do if you knew you couldnt fail?
13B N/A powered 1600 racecar build (Built, not bought) http://www.ozdat.com/forum/viewtopic.php?f=33&t=12316
Munch Munch, L series pistons for lunch
PostPosted: Sun May 31, 2009 3:55 pm
theres also a hook that holds the first bow in the correct position,its either in the middle at the front or back(think its back) then when all bows are in and pulled towards the windscreen it all sits up right
91 GT turbo legacy
GET THAT DATSUN DIFFERENCE!
PostPosted: Thu Apr 29, 2010 12:31 am
In QLD do you need a hoodlining installed to pass roadworthy?
Sam-U-El/Racer135
1972 B110
1978 120Y sdn
1973 B120 - dead
1971 VB110 4dr - sold
Others:
PostPosted: Sat May 01, 2010 3:49 pm
1600 rally cars seem to get away with it,but i got sent to the pits for having a z24 in my wagon,they went over the whole car and said i needed a roof linning
91 GT turbo legacy
