It is currently Wed Jun 05, 2024 2:21 am
PostPosted: Fri Jan 18, 2013 6:44 pm
Hi,
I posted this question on Aussie bluebirds but had no answers so will try here.
I am currently in the process of making coilovers for the front of my bluebird wagon using the hsd sleeve kit welded onto skyline r31 struts.
I was just wondering why people that have done this before have used kyb brand z31 strut inserts?
Could I use a cheaper brand?? Or even just use the r31 inserts that came with the struts I bought?
The inserts i have are peddlers ,and with the sleeve welded in place seem fine for length etc.
Any help on this matter would be great.
Cheers.
PostPosted: Fri Jan 18, 2013 7:35 pm
Buy the best shocks you can afford
They are the one part that you have to spend good money on.
Pedders=Crap
Standard r31=Crapper
Monroes=Up there with the worst you can buy
KYB monotube = good, well priced shock
Koni Reds= Little more expensive but well worth the extra
Koni Yellow=relatively expensive. Like koni red but adjustable. Not really worth it for the street.
PostPosted: Fri Jan 18, 2013 8:04 pm
Ha, awesome reply . thanks heaps.
PostPosted: Fri Jan 18, 2013 8:28 pm
KYB Z31 is good value @ around $250 a pair.
They are better rate than the R31 KYB & a better fit than the R31 as they are around 15mm shorter.
This allows a 200 mm free length spring to fit perfectly.
Also you need to take into consideration the number of coils & diameter of the wire to select the correct
bump stop length. You will need the correct gland nut to suit the R31 tube.
