What exactly do you want to buy??
Front coil overs?
Rear coilivers?
Camber plates?
I'll give you a few things to research, these are just things I would be thinking about,
I don't have coil overs or have had any experience with them yet.
There front coil overs use 280zx struts, there not common here, what wheel offsets will these suit?, the threaded sleeves on the coil overs look alloy, I'm sure steel would be better with double lock nuts(research steel v alloy)
The Rear coil overs are just a shock with a shaft collar holding the threaded sleeve on the shock, definitely looks dodgy, there are better looking rear coil overs, or check this thread out.
http://community.ratsun.net/topic/45858 ... upe/page-3
He gives you the part numbers to build some coil overs from summit racing parts.
Camber plates, I'd really research this or ask in the Ozdat forum for advice from people running camber plates, but I really fail to see how these could operate smoothly and avoid heavy steering without a proper bearing for turning. I know they offer a needle bearing top hat but it's still not like a standard type bearing.
Really do your research with these, and i highly recommend checking out datsports camber plates, they have a standard type bearing to take steering load.
