It is currently Thu May 23, 2024 1:31 pm
 Post subject: Nissan C80
PostPosted: Sat Oct 17, 2015 10:13 pm
Site Admin
I bought this off a kid out near Malmsbury in western Vic, a couple of years ago for $650.00 after being egged on by Graeme Harlor from NSW.
Truth was that I'd been casually looking for a 'Tow Truck' for a little while & when this popped up I though 'that'd be perfect!'. How wrong I was...
When I collected it, it had NO brakes, it over heated & once I got it home (a 4 hour drive through Melbourne!) it was in slightly worse condition than I expected :(
Before I drove it home:
Home:
The mighty Nissan H30 engine!
At some point in it's life it'd been used for carting Hay, as evedenced by someone standing on the roof to load the bales:
This was going to be an issue - crack exhaust manifold:
Classic Auto Fabrications:
 Post subject: Re: Nissan C80
PostPosted: Sat Oct 17, 2015 10:29 pm
Site Admin
I thought about my options for a few weeks, but the Ol' Boy had different idea's & persuaded me to crack on with the repairs...
The brakes needed attention first & foremost and as the fronts were leaking, I removed them sent them off for reconditioning. I got them back with new Stainless sleves fitted - at a cost of $125ea.
There are FOUR of them :(
Next was the brake master cylinder, but this proved much easier & cheaper as it shares the same O-rings as International, Bedford & Dodge trucks of the same vintage, & I was able to reco them myself.
At the same time I fitted new front brake hoses courtesy of Enzed.
We bled the system, took it for a drive around the yard & immediately blew the rear wheel cylinders :cry:
Nothing else for it - strip the rear axles down to access the rear wheel cylinders.
At which point I got a surprise - curved wheel cylinders!
I managed to find a Nissan part number for the rear wheel cylinders (NLA from Nissan), so a call to Auto Surplus was made & they were able to cross reference & find me some replacements O-Rings.
Thankfully the cylinder bores were in VGC after a light hone & I was able to rebuild & refit them - I now had working brakes!
PostPosted: Sat Oct 17, 2015 10:48 pm
Site Admin
With the brakes sorted, it was time to concentrate on the over-heating issue.
I attempted to back-flush the radiator, but I was getting an awful lot of mud & rust coming out & not a lot of water...
Nothing else for it - I dropped the air scoop, pulled the radiator and took it into my local radiator shop for them to pull the tanks off & flush the core.
An hour later I get a phone call from Big Jim from the Radiator shop: "you core's stuffed mate, but I can get you a new core & reco it for $530.00..."
:cry:
This POS is getting expensive...
New radiator it was as I couldn't find a replacement or a different solution.
When I removed the radiator hoses, the water pump outlet that the top radiator hose connects to had corroded away. The bearing was also a bit notchy.
Thankfully as the H30 is the 6cyl version of the H20 4cyl found in Roadsters & Forklifts, new water pumps are easy to come buy - there goes another $100.00...
I also bought a new thermostat while I was at it, as there wasn't one in it when I bought it!
The cooling system now seems to have stabilized in temp, but a dose of Kero & water to flush out the block is in order...
Next was the the cracked exhaust manifold to fix, & so I bought a new manifold gasket from Nissan in preparation:
I removed the manifolds & then attempted to weld up the crack with a cast Iron welding rod, but sadly the material the manifold was cast from turned out to be un-weldable... :(
We pushed the C80 into the shed & it sat there for 12 months or so while I tried to find a solution...
PostPosted: Sun Oct 18, 2015 12:11 am
Looks good Lurch, keep the updates coming :)
PostPosted: Sun Oct 18, 2015 8:46 am
Site Admin
Oh, there is more to come Alister!
The C80 wasn't 'completely' forgotten however - the Ol' Boy's interest in it got the better of him.
The C80 is stored at my parents place (I have no room at mine) & one night I popped around after work to find the Ol' Boy had
replaced the broken side indicators with some Pajero items, fixed the non-working headlights, tail lights, front indicators, horn and a couple of other non-working electrical items.
I got a bit enthused again, so I began the hunt for a replacement exhaust manifold OR a set of extractors.
A common failure with the C80's was a cracked exhaust manifold, so on the few C80's I know what are running, they have extractors fitted (Graeme's in NSW being one).
Phone calls to various exhaust company's yielded no results sadly :(
I resigned myself to the fact that I was going to have to begrudgingly build a set of pipes myself, so I procured some H-series exhaust flanges via Lou the Datsun Roadster specialist,
as well as a box of mandrel exhaust bends, & started planning...
At the end of last year (2014) I happened to do some work with a pommy bloke called Tim, who as it happened was a bit of a guru at building exhausts & extractors.
Tim was so much of a guru that he actually spent time working in Cologne, Germany for the Toyota F1 team building their exhaust systems.............
So I booked him in earlier this year & we got cracking:
2 looooong days & they were finished. I learnt a lot from Tim & the amount he does just by eye had me surprised.
After media blasting & a couple of coats of Pot Belly Black, they were ready to go on with the rest of the exhaust I built.
PostPosted: Sun Oct 18, 2015 10:26 am
Something different. What's the H30 like to drive? Does it feel torquey and decent enough to use as a tow truck?
Keen to see where this heads. Keep at it, seems like your old boy has more motivation than you ha.
douglasamills wrote:
1600s arent the only datsun
PostPosted: Sun Oct 18, 2015 10:33 am
Good work lurch, looks like it will be a great tow truck in the end.
Nice lick of paint and the tray tidying up will make it look good
PostPosted: Sun Oct 18, 2015 3:34 pm
I like these old things, Richard on 1000.com also has a couple he is using to display his 1000 ute
I prefer the H30 and H20 almost over any datsun motor, they are tough as they come.
http://www.tomeipowered.com/BTE/index.p ... tory/2546/
was a 3 time winner with this engine :))))
In all honesty I thought the Cab 80 had the P40 engines like the Pootrols
PostPosted: Sun Oct 18, 2015 6:01 pm
Site Admin
It performs very well, lots of torque & it will rev if you want it to. I normally take off in 2nd gear as 1st is very short. 1st would be perfect for a loaded hill start.
2nd to 3rd is a reasonable gap, but the gap from 3rd to 4th is HUGE, so you need some decent road speed & revs before you grab 4th.
When I bought it, it sat on 100kph all the way home without a problem (apart from overheating). I should probably fit a Tacho...
The Ol' Boy just doesn't want it sitting in the shed doing nothing! I'm motivated again, so progress will be made!
I don't own a vehicle with 'patina' Hayden, so guess where this is heading...
PostPosted: Sun Oct 18, 2015 8:07 pm
Bare metal respray with House of Kolor custom mix?
Hopefully not. What are your plans, more of a tidy up and then a banana-back tow truck?
PostPosted: Sun Oct 18, 2015 8:51 pm
This thing is awesome man I'll defiantly be checking for updates
PostPosted: Sun Oct 18, 2015 9:37 pm
Site Admin
Correct! Candy Apple Magenta!
Yeah, more tidying up still to do Al, then clear coat the cab & then Banana back it :wink:
PostPosted: Sun Oct 18, 2015 9:44 pm
Site Admin
So the observant of you may have noticed in the photo above of the extractors being made that there is also a manifold in place & some Hitachi's in view...
Late last year (2014) I happened to be speaking to an acquaintance of mine in Japan & in passing told him what I was up to.
I mentioned that it'd be great to take advantage of the new extractors (when I build them) with some better induction, over the tiny downdraft Hitachi...
A longer than normal pause occurred on the other end of the line...
"I'll call you back in a couple of days." *click*
A few days later, via a friend, of a friend... of a friend who had a heap of bizarre Nissan/Datsun 'parts' in Japan, I was able to purchase a very VERY rare manifold.
What you see there is a triple side draft manifold to suit a Nissan H30! :shock:
As it turned out, the manifold was 'apparently' originally fitted to a H30 powered Nissan President that was used for 'diplomatic duties' in Japan.
When I received it, it was badly damaged - cracked in multiple places, bent & missing it's linkage arrangement.
A few hours over a few weekends went into repairing it and getting it back into usable condition, and I already had enough parts in my collection to make a suitable linkage setup,
Interestingly the bolt pattern is for 1.5inch Hitachi's (SU's) and I already had a set of twin 1.5inch Hitachi's from a Stanza SSS in my parts bin and a friend in Melbourne gave me the 3rd one, after which they were all reconditioned with 240Z needles & needle tubes.
A couple of weekends ago I finally got a chance to install them on the H30, along with a custom fuel rail (made from 5/16 & 1/4 Bundy tube silver soldered together) and a heat shield I made
from some 2.5mm Alum off-cut.
(Not quite finished in this photo)
So after all this effort, swearing & banged knuckles, it was time to hit the key...
PostPosted: Mon Oct 19, 2015 1:35 pm
Very interesting, great to see something completely different.
PostPosted: Mon Oct 19, 2015 2:50 pm
Awesome. The induction noises coming from underneath the cab are certainly going to be interesting.
