It is currently Wed Jun 05, 2024 1:03 pm
 Post subject: r31 shock in 200b struts
PostPosted: Tue Feb 15, 2005 6:18 pm
would r31 shockies fit into 200b struts if the struts were cut down to the right lenght, -50mm?? or are the diameters of the strut diffrent????
PostPosted: Tue Feb 15, 2005 6:35 pm
I got this done recently.
They cut down the 200b tube and welded a new thread on the top.
Then they welded a steel ring (spacer) on the bottom of the R31 strut insert to make it all fit properly.
By the way I used 30mm lowered King springs, Noltec adjustable strut tops,whiteline swaybar, KYB inserts and KYB mono shocks on the back (180b sss).
Really impressed with this setup but I do need more negative camber.
Also considering a rear swaybar and a rear camber kit.
1973 Datsun 610SSS long term resto-mod project
1983 SII Datsun/Nissan 910 short term daily driver/fun resto-mod project
PostPosted: Tue Feb 15, 2005 11:01 pm
thanks mikka
just what i wanted to hear 8)
PostPosted: Wed Feb 16, 2005 10:40 am
Did you fit R31 tops :?:
The R31 top has neg camber in the std position & has plenty neg adjustment.
If additional camber is reguired on those tops they must
have the inside of the sliding plate ground down so that it
will not foul on the inner panel.
Nice ride with the KYBs :wink:
